Thread Starter #941
That’s hilarious 😂
Agree, at first I thought it was a junkie shooting up, ya know like when you go to Home Depot and get mobbed by illegals sitting in the shade wanting to install what ever you just got done loading in your truck, then I looked closer saw it was a different kind of junkie, a tuner type junkie 😂
leakdown and borescope looks fantastic - she's ready for the Big W! Have to say, a well-sized and tuned corn fuel system is quite impressive.
Thread Starter #943
Speaking of fuel system, new fuel pumps arrived today.
Along with a 3.00 pulley a buddy of mine sent me and that bracket from Nitrous Outlet for the insulator spacers. On Sunday!!
7B7C394D-F95B-4E70-978E-ED7CAE3C79D7.jpeg C72E9318-E909-48CD-BD24-72D1D0512349.jpeg
And 16 new plugs too!! :)
With any luck should be running by next weekend. I plan on insulating the coolant lines right to the inlets on the blower, rather not cosmetic wise but they need to be for maximum cooling.
Wouldn’t maximum cooling require an ice box 😉
Thread Starter #945
Chiller gets the water to 28 F sometimes, unless your putting dry ice in that box your not going to get the coolant that cold with ice alone :)
But I agree one would help but hoping the double pass intercooler in the Whipple is happy with 40F coolant as the chiller makes that most all the time. But before I went through the hassle of an ice box I’d add a second chiller block in parallel with the first. Mines a street car predominantly remember.
I want to see that bracket on when you are putting it together
Are you clocking your plugs still? Wondering if the borescope could be used there if if you’re just marking on the plug where the electrode is.
Thread Starter #948
Yes, I clock the plugs towards the intake valve or center of cylinder on everything I put plugs in, The more high-performance the application the more picky I become that they’re facing where I want them. But yes I just mark the socket and the extension with black market to match the electrode position, That works easy enough.
I'm gonna ping you when I get ready to swap blowers. I need those pointers you've picked up on fluid management. I don't have an engine hoist so me and Crew Chief Greg will have to wrestle the blower off the car by hand.
Thread Starter #950
If I had to lift it off by hand with 2 people for the sake of protecting my car I’d sling it just like I did but instead of attaching to the engine hoist if you don’t have one substitute a 2x4x8ft for the hoist hook and lift it that way one guy on each end up and out, easy peasy. To try and lean over the car from each side and lift and walk it out the front is asking for disaster even if it’s just a elbow dent in a fender that’s too much!!!
Where can I get the eyelets to screw in to the blower? I may have to come up with something
@vortecd pulled his off using the 2 person method once. Without issue. That was before we met so I wasn't a part of it.
Thread Starter #953
McMaster Carr 4843T11 M6 Eyebolt
Those spacers for behind Litens pulleys, McMaster #’s below
F5C2E718-3CDA-4A84-884B-B989C2B16B28.jpeg C46D63F5-ED67-4805-93D7-26C2D7902C70.jpeg 5C1924D3-FAA6-45CF-8C10-442CD461E9E9.jpeg
did you custom make the lift cable lengths, or are they some kind of standard bicycle lock type?
Thread Starter #955
They might be from McMaster Carr as well, let me look to see where they came from tomorrow
my story I'm sticking to it:LOL:
I pulled mine by myself you panty-waists
:p
:p
For me it was more a height thing, you are how tall:whistle:
Keep in mind I have to use a crate to wash the roof of the car
Being serious, they are just over 100lbs.
The trick for me was to lift up the front enough to get some short sections of 3/4" hardwood pieces underneath the front of blower and raise it up, then I could rock the rear up and get more sections of hardwood under the rear.
That got it up above the pins.
Then I was able to slide it forward on 2*4s.
Like so...
Then it wasn't so far away and I was able to lift it, pivot around, and immediately set it down on a table behind me.
