HELLCAT 1/4 MILE TIME LIST
Jonjonday
Ocala
2015 Hellcat Charger
And the coefficient of friction is altered by tire pressure...
Wheel hop can absolutely be controlled by tire pressure and burnout duration as well as other factors
Absolutely. Anything that can change the coefficient of friction point to avoid stick/slip as the SRT engineers called it will change when and if it occurs. On my old car I added horse power and it went away, I was blowing through it.
Thread Starter #263
Dude that is 9.20 in the 1/8 mile . Stop trying to cheat ....
Thread Starter #265
hell james I gave him the hit:LOL:
Oh I seen that I figured it was you trying to figure out which pedal to push down
Thread Starter #267
I was working on the trans brake (dear God don't let the trans break everydamn thing else has )
Lol
Kind of figured, will be starting with 19 cold tire pressure next outing
Thanks for the advice as well
My car is A8 & I run 22 psi in my 315's , best 60' is 1.44 , you being a M6 car may need a little less ?
Putting on a FAS billet inlet plate this week myself, will be trying that Fastman TB on stock snout first before porting a snout and going with a bigger TB someday if this setup doesn’t net 50 additional HP
I would love to see what the plate adds by itself. I really believe it needs to be with the snout and TB to get the "best" gains. I'm kicking myself for not putting it on this round with my snout and TB. It frees up enough airflow to require tune adjustments and will add some boost.
Did you try that throttle body
Ok, after MUCH ado here’s the results
FAS Billet plate, port matched my snout to the plate inlet, Fastman 95mm TB. Before and after, dyno 2/17/20 3 pulls, dyno this past Sunday 2 ditto pulls, no other changes, didn’t even disconnect the battery or do a throttle relearn. Look at that baby breath now in the top end. Added 2-3 mph to the top of my 1/4 runs
Thread Starter #271
Awesome mike
Thread Starter #272
Hey can’t see the numbers how much did you actually gain hp & torque???
THANK YOU for the Fastman TB, seems a perfect match here. I was shooting for 50 hp (Or more lol) and this combo nailed it.
Here’s a pic of what needed hogged out of the stock snout, only took about 2 hours with a die grinder.
50 solid HP and about 20 ft lbs tq but more impressive then the peak numbers is the area under the curve difference of both after about 5300 rpm
I posted a pic of the dyno graph did it not come through?
Thread Starter #275
Look at this jewel it will swallow the stock one EEAA7BAF-CC51-46BE-904D-D33682C8310A.jpeg 8AB58E29-AFD7-4F4C-B26F-4A3DAA5FA6E6.jpeg 295C942E-D6A5-44DF-8E27-EAB38D29B75C.jpeg 984BB87A-2ADD-4255-BBC7-F5D6B832499C.jpeg
WOW , & gosh damn that big ! ….that's what she said. :LOL:
That looks nice !
Thread Starter #277
The supercharger is s supposed to be back today and the snout tomorrow I’m exited to see how much I gain , at the track of course I don’t dyno mine
That's awesome Dave !
Can't wait to see this too , so it should be running on Friday , GL.
Man that definitely is one big ass throttle body!!
Next up for testing is massage the stock blower inlet plate and put it on my other blower once I fix it and see how much it nets verse a $1000 plate. I don’t see that test occurring for a couple months but if will happen, I bet it’s close.
