Eternal 1.5 60’ club…
I
watched a video for eibach ones for lowering springs and I thought you needed to press them in where you need them and then there’s no adjusting after that
I won't need to adjust after. Just need to get the tire more square to the road.
Injectors, blower, diff and axles plus I will be needing tired. Because of all that the budget require these or nothing. Since the ass end is coming apart I will do these bushings. A friend of mine has been using them for years.
U
Thread Starter #42
You may want to go with a 3.09 or 2.62? You have way too much of a torque multiplier with the 3.70! It’s over a 40% higher torque multiplier than with a 2.62 in first gear! You need some monster slicks and wheelie bars!
Yep I think it’s like 14x torque multiplication in 1st gear
U
Thread Starter #43
What happened to being stock lol. That’s awesome, if you can get me the Moog part number I’d like to give them a shot but would be afraid that I would install them incorrectly and be doa
Wow! That thing has to be a pretty touchy beast on the street! I think the 8 speed auto has a 4.71 first gear. 4.71x3.70= 17.4 multiple. In the old days, we ran a 4.56 rear with a Hemi 4 speed and a 2.65 first gear ratio (12.1 multiple). That was barely streetable without adding an overdrive. I think to get better traction you will either need to change the rear or start running a 32” tall tire!
Being stock ended when I had to get a tune to fix the car over temp issue after the recall in Nov 2021.
So at the moment it's a tune only for pump gas. Someone on the other forum doesn't get that stock boost doesn't necessarily mean stock. It also doesn't put the car in ProMod category.🤣
Hpindy was selling his blower so I figured I would grab it. I just got axles because my limited slip isn't the happiest and after 1500 or so runs my stock axles aren't going to like 1.4 60' for much longer. So I guess my car is heavily modified now because I want it to run properly and not destroy the bottom of the car when drivetrain parts decide to exit.
So f it once I get my 9 sec pass with stock pullies and on 94 then the blower gets swapped and I will find out what it's capabilities are.🤣
Now you know the plans.😉
The Moog number is K100173
U
Thread Starter #46
Yep! Mad the 315/55r17 came out right after I bought my 315/50s. I believe the 315/55 is almost 32” tall
U
Thread Starter #47
