why2kmax
12 Second Best E/T
Shrewsbury
Im going with slight decrease throughout.
No difference
My guess the throttle body failed and you have no results 😂😂😂😂
Thread Starter #785
Nope, it ran without hick up, guess again. I’ll post screen shots tomorrow of run logs of the pulls of each TB to aid guesses.
Thread Starter #786
Double posts don’t count towards the power ball
Thread Starter #787
No more guesses by anyone??
Walland
21 Challenger Super Stock
The suspense is killing us😆😆😆
You removed load from the dyno to get it to read the numbers you want?
Thread Starter #790
how did you guess we took a drill and started drilling holes in the roller to lighten it up from 4400 lbs 1/4” hole at a time. Your a Genius!!! But we got tired after 100 holes snd only 2 lbs gone, so your still wrong, no prize for you.
Thread Starter #791
Come on, no one reading this informational thread any more? This is good data here waiting for a winner. Wife has had me doing honey do it so I haven’t had a chance to post 2 clues yet
969 hp 890 tq
Thread Starter #793
Question is Not what it made peak Question was why is there a difference between 100 mm throttlebody and 105 mm throttlebody. Did the bigger 105mm throttle body make more, less, or the same horsepower and torque as the 100 mm TB??
Thread Starter #794
Here’s some hints, model of TB noted at bottom of each picture.
8698CADB-A036-47DC-B7FE-84415CCF675F.jpeg A0F1F773-8B24-40F6-92E4-2A862AF37F59.jpeg F3043C27-E017-41D5-9E41-30FE98DF55E1.jpeg 17A7A1D4-6EBB-4138-9A53-2C742D48DA9E.jpeg
HHP made less. The turbulence introduced by the step down to the snout caused more harm than good.
Thread Starter #796
More opinions? @Speedy! @Hpindy you care to chime in and take a gander?
Thread Starter #797
The devil is in the details presented, who’s gonna see him???
I see elevated IATs…
I also see more fuel consumption with the HHP… that should mean more air and more power… hmm.
Too hard to tell in line for rides in Dollywood… ;)
Was it actually 105mm all the way through? I know you said you needed to measure the throttle blade. You were also dealing with a snout that isn't 105mm. My thought lets say the snout was 109mm and the 105mm and 100mm are what they say I would think the difference would be very small.
My car is flowing way more with the pulley and I could test the stock and BBK being I have one but Jon's car has a stock throttle body because Simon said there was no power with a bigger one. That 2.7 is flowing way more air then mine.
Thread Starter #800
Blade on the HHP105 is a true 105mm, the OD on the air intake tube is larger as well, matches the OD of the JLT tube, no more step down rubber connector, the HHP uses size for size, smooth transition from the JLT on the inlet side. My snout is only opened up to 100mm to match the BBK100 and to retain the factory gasket and groove. I have a snout that opened up to 105 on the way.
