With that much pull it may be slowing the rotational speed of the crank and rods. Wait...now I have to rethink this.:unsure::giggle:
I know Mike said the magnet would not come off, but what if it did ? where would it go or possibly end up at, just stay in the pan or grab something rotating ? :eek:
Our engines have windage trays don't they ?
I guess a loose magnet would prob. stick to that or oil pick up screen / tube ?
I think I answered my own question, but need others input / thoughts ?
Mike is the Hellcat God. He has ties to NASA, laboratories, machine shops, and other really top secret, high tech stuff. He would NEVER let that happen. NEVER. How dare you. HOW DARE YOU! (Yeah.... thought occurred to me.:LOL:)
Yeah, how dare me, but the concerns are there, best to ask the questions first than to ask after something happens.
I'm sure it'll be excellently made, just wondering what if. ;)
Seriously, I wouldn't give it a thought. The magnet is recessed/press fit into the bolt. If it ever became dislodged the goddam thing is so powerful it would pull itself to the nearest ferrous metal (ie. the bolt) and wouldn't get swept up into the current and go into the assembly. It would come out with the bolt on the next oil change.
I agree, if it comes off, I guess it will just stick to the bolt, so to that point it might get loose ( if possible ) but should still stay on the bolt.
I feel better now. :LOL:
The magnet will be attached to a steel drain plug, it isn't going anywhere:)
I actually put one on my car last year on it's first oil change. Only thing I didn't like about it, it uses an aluminum washer. Not really sure why they couldn't make it like a factory one. I may be in for one of these also. Sounds like it has a more powerful magnet
If it helps pulling the crank around does it mean I have an electric car or just a hybrid I guess:unsure:
Hey @16GoManGoHC2 , my next oil change is in September, I hope that I can get the 2 plugs by then, no pressure LOL, would be nice though.
Thread Starter #448
Magnets are press fit into the plugs at least 1/4”, and have loctite 680 on them as well and sometimes JB Weld, probably have to bust them to get one out. Have no worries of them coming loose, I wouldn’t use them myself if I had worries, I’ve been making them for decades for industrial equipment and my vehicles, keeps me from having to send oils out for metal analysis, the magnets tell me what I need to know!! I have them in everything, my transmissions have 2 huge ones in them with opposing polarities so they make a field between them. My lawn mowers even have them in them lol. This one was for the kids RX8
https://youtube.com/shorts/SZVSbdo9Kio?feature=share
Thread Starter #449
I’ll have some ready in the next week, waiting on plug shipment from dealer, snd now need to order oil cooler line plugs too, I’ll get them on order tomorrow.
Now you opened up a can of worms LOL, what about the Transmission drain plug, rear diff plugs ?
I’m down for oil pan, oil cooler and diff. (If and when.)
Thread Starter #453
Yep, I make them too lol. Next time under the car I’ll show you a picture of a wrench sticking to the out side of the trans fill snd drain plugs lol. The trans fill plug is a perfect place because the splash off of 234 gears is directed right towards it so it catches everything
Thread Starter #454
So today being it was supposed to rain and it didn’t LOL so I did a leak down test on cylinders that were easy to get to which was 3, 5 and 7, 7 was the problem child that lead to this rebuild had to be honed the most due to a hair of heat distortion ( honed out only .0025” to get perfectly round and no taper) and became the target cylinder for the rest, it only has 1 1/2 % leak down at the moment I think that’s pretty damn good for gapped style rings COLD and less then 75 miles of run time!! Plateau honing and 3F81BFE9-8355-479D-9840-166AE057CE6C.jpeg E1684520-0FAC-48BF-8D73-CEF0CBF37555.jpeg 7AFD27B3-0B95-4B95-A2D3-F36CA28F2E19.jpeg DC4127AB-49F8-41B5-8D50-1B095305EBF6.jpeg 253DDDDB-7FBC-436B-B031-09C13419B538.jpeg 8BDD4AA9-DFEC-482E-91EF-F8B2BDF45B62.jpeg A7C50A69-B48E-4862-B4EF-FFF87A0611CE.jpeg F14B9D08-A7CB-464C-AE49-AC83576FDFD1.jpeg 04BD243B-1BDB-4ECB-AD8B-D7FD34A758E1.jpeg AF67B725-3274-4862-A66C-76D2D1BD6775.jpeg 3C908EB6-07D3-47F9-BB8B-8C6374C30828.jpeg 1BF1DB63-F386-4CAB-893D-FF763FC77CC0.jpeg ADABDFC5-1E68-4616-A398-371F3862A85A.jpeg 43FAACA7-CB8A-4F44-8190-1FDD671458E2.jpeg Quick Seat worked well together it looks like. Notice heat band on ground strap right about at the halfway point, perfect!!
You have M6, would that be true for the A8 also ?
So today being it was supposed to rain and it didn’t LOL so I did a leak down test on cylinders that were easy to get to which was 3, 5 and 7, 7 was the problem child that lead to this rebuild had to be honed the most due to a hair of heat distortion ( honed out only .0025” to get perfectly round and no taper) and became the target cylinder for the rest, it only has 1 1/2 % leak down at the moment I think that’s pretty damn good for gapped style rings COLD and less then 75 miles of run time!! Plateau honing and View attachment 48877 View attachment 48878 View attachment 48879 View attachment 48880 View attachment 48881 View attachment 48882 View attachment 48883 View attachment 48884 View attachment 48885 View attachment 48886 View attachment 48887 View attachment 48888 View attachment 48889 View attachment 48890 Quick Seat worked well together it looks like. Notice heat band on ground strap right about at the halfway point, perfect!!
Good results, she's healthy !
Thread Starter #457
No idea on the A8, but most auto’s already have a bunch of magnets in their pans already usually right where fluid returns are dumping back in plus autos have filters on the pic up, HC M6’s just recirculate the stuff, out to cooler and back no filter.
Uhaul rents trailers you know. A guy comes to CF from Canada and uses one of those ;)
Thread Starter #459
Ahhh, that is an idea!! My 4Runner isn’t Supercharged like yours though you know lol. The cat weighs more then it even without the trailer!! It’d take me a week to get there lol 😂
Million $$ question is,,, wood you be better with or with out it?? Better with or with out it??? Or just no plug at all and sea how far you get??? Time fer a shine and mango drank.
