    Welcome to the #1 Dodge Hellcat Forum and Hellcat community dedicated to Hellcat owners and enthusiasts. Register for an account, it's free and it's easy, so don't hesitate to join the Hellcat Forum today!
Harmon Kardon Sound system on the Hellcat
Fairfield
What I Drive
All I put in mine was an AP4 module which you have to have and a JL audio 6 ch amp. It will blow your mind how good it sounds.
I would love more details, if you can ask your installer. I've read the stock amplifier is 11 channels, so how does the JL Audio power up 11 channels, or is your installer using two amplifiers, the JL to power the front 6 channels and using the stock amplifier to power the rear speakers and subwoofer?
SpecOps Veteran
Fayettevile
NC
What I Drive
2019 Hellcat Charger
Can you run that amp via the factory head or is there a seperate remote for this amp?
It runs on the factory head unit through the AP4 module (Link posted in subsequent post).
SpecOps Veteran
Fayettevile
NC
What I Drive
I will forward this page to my installer and see if I can get him to answer the questions. Bear with me, I haven't forgotten you!
V/R
Fairfield
What I Drive
V/R
Awesome... thank you! My assumption is that they used the JL amplifier to power the two subs, two door speakers and two of the passive mids/tweeters, while the rest of the speakers were powered by the stock amplifier. Most audio people only care about the front stage, which is the most important to the driver.
I may year into the system this weekend to see the speaker specs, really curious about it.
SpecOps Veteran
Fayettevile
NC
What I Drive
Something to do with the ohm's but they ran 2 pair of speakers off each channel. because i had a JL 12" sub they disconnected the factory sub. They called me during the install and had everything shut down except for the sub on the factory amp and the output was so pathetic they recommended just disconnecting it entirely, which I had them do. The factory amp only runs the speakers in the middle of the dash and the back, everything else is ran by the JL 6ch amp. They do make an 8ch amp which they said I would need if I wanted to retain use of the factory subs. Since I have the heavy hitting JL W6 12" I didn't see a need for the factory subs. I am still waiting to hear back about ohm's and load etc.
Fairfield
What I Drive
Awesome, that is what I thought they did, using four channels of the amplifier to power the front stage and probably bridged two channels to power your JL Audio 12" sub, which probably pounds now.
This gives me exactly was is needed, and an 8 channel amplifier would be more useful if one was to separate the front mids and tweeter and go active with an amplifier like the Helix V Eight DSP, or keep the stock passive set-up and power with that JL Amplifier, or I would go with a Helix P Six DSP mainly because I want better Bluetooth streaming and Helix makes a Bluetooth device that processes the Bluetooth much better than our stock system.
Very helpful, thank you!
SpecOps Veteran
Fayettevile
NC
What I Drive
I'll take a picture of the install after work, might give you a better idea of how they did it if you can see the wires.
Fairfield
What I Drive
One thing I forgot to ask was did you remove the HK subwoofer box, or was the 12" JL Audio woofer able to fit in the box?
SpecOps Veteran
Fayettevile
NC
What I Drive
They didn't remove anything. On the Chargers I am actually not sure where the factory subs are. Ill post a pic of the sub in the trunk and then the amp installation after work.
SpecOps Veteran
Fayettevile
NC
What I Drive
See attached. Hopefully it helps. If you need more clarification etc by all means ask!
Fairfield
What I Drive
This is great! Looks like you have more than originally stated and that subwoofer must be banging with the mono amp. You have two amps, and what looks like the JL Audio XD600/6v2 and the XD600/1v2, with the 6v2 powering the Front stage and that 1v2 powering the subwoofer.
Great system, must sound great! I cannot wait to dive into this build. Appreciate all the posts and pics!!!
SpecOps Veteran
Fayettevile
NC
What I Drive
Yes I’m sorry I thought I mentioned I had 2 amps. One is the 6ch amp for miss and the other is a 4ch amp bridged to the sub. It sounds like you would think a $1700 option HK system would sound like, absolutely badass.
Fairfield
What I Drive
Agreed, for $1,700 one would think it would be awesome. This system is awesome to the average person, but to an audio person it is not very good.
I learned my lesson to never pay a premium for a manufacturer's audio upgrade as they are not built with high quality equipment, just mediocre stuff like this Harman Kardon equipment, not saying it's bad, but your JL Audio is much better, Arc Audio, Hybrid Audio Tech, Audiofrog and my personal favorite Audiotec Fischer are a few other brands that come to mind that blow Harman Kardon away and can be had for a similar price.
Live and learn they say...
What I Drive
I don't know, but my K & N 900 watt 17 speaker blew one of my windows out and I thought that was enough. Use to J B Ls and Marantz speaker's, amp, pre amps 1000 watts. This system seems to be doing very well not over dong it with the power it as to offer. My vettes had JBLs and did very well. The K & N has dual 8 inch dual woofers with a 12 volt full size battery with no room for a battery. No room for a spare tire or jack. Just a tire pressure gauge and accessories. That was enough. Still have the car,,, having the engine painted,, and 800 h/p out runs El Ric's Red Eye and like Rico's Red Eye and him. Not too many Demons around. Hogans and that's about it.
