Darrel Cox lithium battery issues
Ricky Racer
Ricky Racer
Vancouver
2018, dodge demon
Thread Starter #21
Battery update; after a full weekend of racing, once at Portland international raceway (1/8 mile) and then Woodburn drag strip (1/4 mile) the 8 pound Darrel Cox lithium battery held up. I did not have to charge the battery at the track as I did not use the after race cool down feature on the car. After each run you just pop the hood and let the motor cool down that way. The real story is how much the car picked up! It ran a tenth and a half faster at the eight mile and two tenths faster in the quarter mile. Now granted we did have fairly good air at Woodburn yesterday but at Portland international raceway last Wednesday the air was horrible ( 90 degrees, 2763 DA). The car charged the battery sufficiently between runs as long as you don’t use the after race cool down. Battery voltage stayed at 14.1. I like this battery so far, we will see how well it holds up over time.
I have one of the Cox batts in the blue car and the Arc Angle in the white one. Both kick ass as far as starting the car goes. A couple of “tools” I take to the track….. my 2000kw generator. It’s less than 40 lbs and is so quiet you’ll forget it’s running. I keep a small LifePO4 charger next to the battery in the car and plug it in to freshen up the battery if I want to. These lithium batters charge super fast. Last but not least…. A fan (Jegs) that is designed for cooling down a motor fast. AD3FAF2F-95F9-46CB-AD40-0B89E9B74D08.jpeg 595E1380-958F-4689-92B1-F7482D954BB4.jpeg
Ricky Racer
Ricky Racer
Vancouver
2018, dodge demon
Thread Starter #23
I have one of the Cox batts in the blue car and the Arc Angle in the white one. Both kick ass as far as starting the car goes. A couple of “tools” I take to the track….. my 2000kw generator. It’s less than 40 lbs and is so quiet you’ll forget it’s running. I keep a small LifePO4 charger next to the battery in the car and plug it in to freshen up the battery if I want to. These lithium batters charge super fast. Last but not least…. A fan (Jegs) that is designed for cooling down a motor fast. View attachment 80294 View attachment 80295
I got to get me one of those!
Buy this battery, drop a tenth! ;)
Saint Paul
Dodge SRT Demon
I never use the race cool down.
It just eats battery.
I leave the hood closed all day long.
To keep the heat in.
Bracket racer.
Bracket racer.
i never leave my hood closed. Even if I were to bracket race I wouldn't because it would heat sock everything and slow down
Ricky Racer
Ricky Racer
Vancouver
2018, dodge demon
Thread Starter #27
Can’t seem to find that fan on the jegs website anywhere, what’s it called exactly or a part number. Thanks
@zhc had 2 of them but I'm not finding them either
. I checked and they don’t have them anymore. I found this on Amazon. It is similar in design in that it draws from the top and can be placed where you want it. 2F94CCCA-D4A6-4926-A6E8-03AF29DBD1F3.jpeg
zhc
2016 Dodge Charger Hellcat
From jegs, just not rebranded, Blower Fan from Jegs
If you do some searching, you might find them on sale somewhere.
Yep that’s it. They kick ass for putting air where you need it. I even set it on the ice chest and use it to blow air in the sitting area next to the trailer. 👍🏼
Ok. A little info on this. It’s labeled as Mr Gasket. They are owned by Holley. This item at Holley says discontinued/not available. That’s what I also found on Speedway. I do not used Jegs for parts anymore. They list stuff as available when it is not. They charge your card and then notify you later that it is months away or not available and then you can jump the hoops to get a refund. Summit doesn’t do that and I use them for most of my stuff now. It is possible that one if these may be in stock somewhere but I would suggest calling and confirming that before a on-line purchase.
TNREDEYE
Shelbyville
2021 Super Stock
750 CFM 1/5 HP Floor Blower (harborfreight.com)
I have one very similar to this. I bought mine from Lowes but I can't find it on their website. At 750 cfm this thing will move a decent amount of air. Price is pretty good too.
