Anyone using a CTEK MUS 4.3 to keep their battery charged?
I’ve been using it for years without issue. Lately only the green light is on, blinking, indicating the charger is plugged in and powered up. No other lights lit, indicating the charger is not “seeing” the battery. Looking at possible causes according to the manual, none exist. The battery is fully charged, according to my other charger, connections are tight, etc. Any thoughts? Thanks.
Have you tried unplugging it, let it sit for a while then fire it up again & cycle thru the 'modes' ??
I had a Noco one that started acting strange like this, didn't last long after.
Been running an MXS 5.0 on the Hellcat for years now with no issues.
Thanks Mike, I did try that. I could always move the charger around but it’s just a pita.
Seems unlikely, but is one of the cables bad? Look for an internal continuity break from flexing?
If the charger isn't seeing the battery voltage correctly, then it's going to behave badly.
I’ll check the cords later, thanks Bull.
Bull for the win!!!!
While not with the cord specifically the fault was in the prongs connecting the cord from the charger to the cord permanently mounted to the battery. Thanks again Bull.
Decay
Astoria
OR
2019 widebody Redeye
Do you folks think/know that running trickle chargers increase the longevity/life of a battery?
I do know that my sideby batteries last a LOT longer when I use a tender and it occurred to me that I should maybe have one on my car in the winter when I only drive it two or three times a month.
Winter here in Astoria Oregon only lasts about three or four months.
The stock Dodge batteries are pretty poor quality anymore.
My Ram was 4 years and the Redeye 3.
YES, as long as they have good charging/float profiles, lead acid definitely degrades when not kept charged.
Have the same one. Weird. Plug it in and it should run through the charging procedure. If it doesn't may e check the connection plug? Other than that something broke inside. It should just work on a decent battery. Mines 5 yrs old. Weird.
Good to go cc. Thanks.
22RENBS2 & 170
I said this in another thread. I have been using HF cheapos for maybe 8-10y. I have not replaced a battery since I started using them. I really like the newer ones they came out with recently, maybe $16 on sale. My Bobcat has a 2012 battery and starts great after sitting all winter. These things are magic!
Parkersburg
WV
2015 Hellcat Challenger
I have been using Battery Tenders on all my power equipment batteries for years and the batteries last a LOT longer than they did before I used the Tenders. Same with any vehicle that sits more than 2 weeks. My 2015 Challenger is still on the original battery and it tests within 5% of nameplate CCA.
Always used the ctek. Not worth risking something bad happening on cheap Chinese junk that was pennies on the dollar. Seems you get what you pay for so 🤷
22RENBS2 & 170
Where is the CTEK manufactured?
