I do want to hear things, in case there's something that doesn't sound right. Wouldn't want to mask one noise with another. Have been blessed with nearly complete quietness for so long that I'm beyond used to it.
There's a reason I don't stop at motels at night and keep driving instead. I couldn't sleep anyway, and not only because of all the noises. Nervously looking out the window every 10 minutes to check if the 3500 and trailer (plus whatever is on the trailer) is still there isn't conducive to good sleep, either.
When I sleep, screw it, I sleep. I have instructed family even if something terrible happens, save it until morning.
You are way too sensitive and need to be around more people if you cannot even stand the sound of forced air and need warm wrenches my friend. Good luck living, because sleeping seems very difficult for you.
Is eating a problem also?:LOL:
CPO Super stock
westminster
2021 Superstock
Clock is running down.... Torn between doing everything, or simplifying... Getting more tired and sore every day... :(
your correct.. you should give me your 170 for the summer to see how you can do with out one.
Watched someone else drive off in the M6... My first HC... Like dogs, I wish I could keep all of them forever... :(
Dang. I almost had my girlfriend talked into buying it yesterday evening.
CPO Super stock
westminster
2021 Superstock
horse shoes and hand grenades... In this case close does not count, A M-6 is cool but he is going to gift me a 170 which is cooler. LOL
@2ndAmend Sure it hurt to see the M-6 go but that 170 is going to be a blast !
I often leave the ear protection on after running the noisy tractor, grinders, etc. since it's not completely quiet here - cars drive by on the road, ravens and magpies make noises. Even more quiet is nice, I think. And I don't need a warm wrench, it just helps my hands feel better.
Sleeping is generally fine - until I wake up way too early (for whatever reason) and can't go back to sleep because the brain cell gets going at 130 mph, with plenty of thoughts that demand attention. Not all bad since I often come up with solutions that never occurred to me during normal awake hours.
What's sucky is that it means even less sleep than the normal, which is between 5-6 hours. Then, every couple of weeks or so, I make up for it by sleeping up to eight hours.
Eating isn't a problem. I almost always eat breakfast and dinner, lunch I often skip to get more done. Well, when at home that is. When on a trip I generally skip eating, for several reasons.
Oil catch can. 2000 road (easy miles) less than one oz. Looks like the oil that came out today.
Also cleaned and re-packed these bitches.
Moved on to the air cleaner. Bite me!! I have two, the Demon model was in it; filthy. Had the refreshed OEM one ready. That SOB connector btw the air box and throttle body wanted some. It lost, all back together now. Bitch!!
She just needs turned over for a while when it is time, oil pressure verified, oil level double check and mechanically I’m good. The wheels and tires will go back on and the QuickJacks get hung later this month. It could be driving weather or it will wait until after March 3rd. Got one more body part that needs changed out. That is why everything is getting done B4 a vacation in two weeks.😂
We can do front suspension porn. Took the picture to remember since I will not get under it until I have the exhaust touched up in May. They need to get my connector pipes more clean for when I switch out the cats. The exhaust connectors downstream look like shit and leak. There is black cat piss on the pipes.
Front suspension, I repacked those darn bushings for the giant BMR adj. sway bar, it has fixed AAD spherical bushing links, look way up top to see the great AAD adj top connector arm. Ha, that OEM sway bar is so mini, it fits in those little pussy slots behind the big shit. She is about ready to run! Road America will be its opener this year.
Wizza
Stafford
VA
2015 Dodge Charger Hellcat
Cracked thru the glacier covering the entry to my second garage yesterday and got the Charger moved to the main double garage yesterday......we took it out to lunch today and all was good in the world
Took it for state inspection due before the end of Feb and realized the traction was sketchy at best on the way out of the shop......wasn't in my humble opinion getting on it but I had tire pressure at 36 average and the sand/grit on the road surface made for a little twist to the rear track the car took.
This car always will humble me quickly
Oh man, cannot believe I just found this product. Thanks to the less than random shit YouTube suggests. I could have really shined up that polished aluminum on the old chopper. Anyway, check out 30 min of work. Before - showing my next wheel barrel to clean compared to the after- finished one. Unfortunately the good looking chrome wheels you see in my street picture have aluminum barrels folks. Never had such an easy and better result at detailing them in six years now! Not perfect but plenty good for wheel barrels.
Before:
After
This…
Walland
23 Challenger Demon 170
That’s good stuff it appears! You could shave in that mirror.
I’m happy with it. The Pre-Clean item is some of the best. It works on other things also. The polish is better than Mothers by about X4. I made some pizza dough I believe I can find enough Olympics to get through the evening.
Demonic Cat
Especially in a few months @ New England Drag way.
Just think you can drive over to the track in comfort & rip off a 9 second run no prob and drive back. When we were young you had to pick one or the other. If ya picked the 9 second it would almost be to radical and unreliable. Some things have changed for the the better!
Slimcat
Jacksonville
NC
2016 Challenger SRT HC
Polished triple trees, man that brings back some memories, I bought a set of those "once"... never again ! I did buy a Fatboy that had the solid alum rims that look like centerlines, this stuff from eagle one IMG_6342.JPG worked great on them. They had been sitting in a barn, spray it on, let it sit 5-10 min an rinse it off with the hose. I was totally amazed how well they came out.
Before:
After
This…
Flitz has been around for years..(I used it in the 70's)...not sure if it still is..but back in the day it was produced in Germany
Slimcat
Jacksonville
NC
My battery hold down bracket was missing, i ordered one an it came today. Got that put on... and went riding around for a couple hours before dark.
Agreed, although I do keep it inside a garage and make sure no one follows me home. I do park it pretty much anywhere except the hood.
Charged up the big lithium battery again. I connected the car back up about one month ago. Damn, they must draw some power. Disconnected it yesterday (need to preserve that shit ass, cheap, junk, DiabloSport modified DCS control module) and it took several hours with the big charger to charge up again. Sooooo… screw that. I am not going to reconnect that car until just a couple of days before I can begin using it again. A few days is enough time for it to electronically put itself together. The Performance Pages seem to need some time to come back. I am sure Mopar has some super secret way to monitor us all the time, so communication needs reestablished or something, but it is strange.
22RENBS2 & 170
Ever use a float charger?
