Chiller aux tank in (getting her down to 24 degrees for IC coolant!!!
2 step installed and tested.
Car about buttoned up.
Just need some good DA and we'll see what she does!
Don't want to jinx it with times, but I ran a 9.8 like clockwork at 141-142 without launching the car at all and just leaving off idle and stabbing the gas. High 1.4 60'.
Now I have : 2.50 pulley from a 2.69. 2" primary Long tube headers. Fully ported snout, bearing plate and upgraded snout and bearing plate bearings. 108mm throttle body. Chiller aux tank to keep it cooler longer. 2 step for launching. Fresh tires.
I have seen others dip into the 8s, but we'll see. Time to shed a bit more weight to make up for heavier front tires and added coolant capacity, will need to get the car on the scales to see what she weighs.
22RENBS2 & 170
What are you using for tires?
Paddle tires. About the only kind that works in swamps.
Remembered the magic of Mothers.;) Lifts the darn white marks right off of those black anodized suspension pieces. I’ll make it look nice now. That is a wicked looking suspension when all the AAD stuff plus is installed. Yea, I’ll get pictures. IMO it still looks like shit. I did not clean it last year. Damn pricks had me working too hard.
Sportsman's up front, et street r in the rear
22RENBS2 & 170
MMissile
Macomb County
2023 Challenger Hellcat WB
I haven't even seen mine, since before Christmas. So, I'm gonna go with ignore.
I look in on mine occasionally...their such good lookin kids...
Wizza
Stafford
VA
So am toying with the idea of having a shop swapping the drive train and all components over from my 2015 charger hellcat into a classic Mopar body and then I don't have to worry about a lot of the same stuff locally that I do now with it being a 2015 For emissions and state registration garbage
It is going to be quite the project if I can find somebody that I can build enough trust with to invest in a good roller and have them do the swap and ensure that everything is functioning
That's a BIG project....o_O;)
22RENBS2 & 170
Local, very high end, custom shop put a HC engine and drive train in a Duster. He said it was pretty much undriveable. Without the OEM stability control tuned for the specific vehicle, it was almost uncontrollable.
The stability control is, IMHO, the most underappreciated facet of the platform. My RES2 has 885hp (mfr rating) and is as easy to drive as any new car off the lot. Lean on the gas and it stays straight and easily controllable. Put that in any car without the stability control, and you are sideways every time you accelerate.
Here is a modded M6 trying to do simple straight line acceleration.
https://www.facebook.com/reel/1280215140558407
Wizza
Stafford
VA
agree totally, there are similar wheel bases I can do a body swap as long as I find a setup for shell that is not janky and I am unable to do a $250k build up...... not happening
may have to admit after doing some research that the Challenger is more skin to having a restomod or body swap than the Charger.........wish I had the time or talent to buy a roller and do the work myself.
Very cool..and interesting project...not something I would ever try on my own...back in the day..(mid 70's) our crew did some wild swaps..most disastrous was a 350 swap in my buddies mothers Vega..those days are long gone..as are most of our crew back then...but those were great times..
...our crew did some wild swaps..most disastrous was a 350 swap in my buddies mothers Vega...
That reminded me of lowering, sectioning, and chopping a Postal Jeep. It came out decent enough that I decided to yank the Chevy 4-banger and put a V8 in it.
Little did I know that the donor car's engine wasn't a 350, but a built 400. No wonder it tried to kill me every time I drove that thing.
22RENBS2 & 170
Friend has a supercharged C7 and a AC Cobra replica. I have never seen him drive the Cobra. He said "all it does is sit there and burn rubber".
Short wheelbase vehicles with lots of power can be quite fun...and also lethal.
