I don't know why cats always run onto my car. There are paw prints on the car cover every time.[hihi]
My issue is little green frogs shitting all over my car.
Stork arrived today! Happy to see the ink is still on the DR's!
Yesterday I was wondering if it would beat the weather to your place. Guess it did, if only barely.
Hmmm..the Cauldron must be full:unsure::unsure:
HangZhou
China
The drive shaft doesn't seem to be secured properly. We might have found the source of the friction noise. IMG_1527.jpeg
Did I miss you going after this or was this done on the downlow?
More pics!
Beautiful blue!
Downlow????o_O
"Secret"
I'm well aware (generally used regarding deviant sexual behavior)
I'm aware as well, it was a gentle but intentional play on the word...
If you're buying a D170, there is some level if "satisfaction" going on somewhere, somehow...
Now speaking of D170s... ; )
HangZhou
China
"Borrowed" a temporary one from the Challenger next door who was mid-upgrade.[bash]
HangZhou
China
After the replacement, all the issues vanished—no more shaking, no weird noises. Now the car runs as smooth as a baby's bottom. (Btw, this part looks pretty fragile—are there any reinforced components for the drive shaft?):LOL:
Slimcat
Jacksonville
NC
2016 Challenger SRT HC
Wanting to keep my car original when the drive shaft (DS) center bearing support went out on it i replaced with an original. Dodge makes you buy the entire DS and its very pricy. There are several other options, like a one piece DS in alum, carbon fiber, or steel. You can also cut away the rubber support and metal bracket then use a JXB 2 piece bracket. If mine breaks again i think that is the direction i will go. I have read good reports on his brackets, and customer support.
would you like to buy one:unsure:
All of my money is tied up in that ~100 acre plot of land in PA that I'm still trying to buy or I would!
100 acres???...gettin back to yer roots...gonna be a farmer???....If you need to borrow some quick cash...I can help you out...(friends and family discounts apply[rofl][rofl])
22RENBS2 & 170
More pics!
Beautiful blue!
It seemed like the more I posted about it, the higher the prices went! So I took it off-line. I found out about it from Cerino on the other forum, he found one new at a dealer and said there were a few more. I grabbed one, another was picked up by a member here.
22RENBS2 & 170
I was pretty much freaking out. It was zero this morning, low of 1 tonight, and 21" of snow coming tomorrow! :mad: I think it was the driver's plan to get in and out quick! I followed your recommendation and used Reliable, it was worth the extra $. It was a husband/wife driver tag team, they picked up Monday in LA, and delivered 10am Friday when it was sunny and 40! And they were in constant touch with updates! Very happy!
06SRT10NR
Knobnation
Wanting to keep my car original when the drive shaft (DS) center bearing support went out on it i replaced with an original. Dodge makes you buy the entire DS and its very pricy. There are several other options, like a one piece DS in alum, carbon fiber, or steel. You can also cut away the rubber support and metal bracket then use a JBX 2 piece bracket. If mine breaks again i think that is the direction i will go. I have read good reports on his brackets, and customer support.
as mentioned, JXB makes a good kit for replacement. Takes ~45 minutes to cut out the old one and bolt up the replacement [without removing the driveshaft]. A lot quicker with the driveshaft removed
https://www.jxbperformance.com/prod...eshaft-center-support-bearing-carrier-upgrade
