AC and Fan Not Working Until it Did
87 and humid here today. Took Mrs. jroyk in the HC to a friend's house to drop something off. All the way there, no AC or fan. Turned the car off briefly there and restarted it. Everything working again.
Any ideas what would cause this weirdness?
Some circuit breakers are self-resetting??
I guess that could be. I was thinking maybe a fuse that wasn't fully seated. Everything was so hot I didn't want to deal with it today. Will do check in tomorrow morning.
It could be the humidity sensor? It’s located in the little plastic box on the windshield next to the rear view mirror. When it goes bad, the inside circulation button doesn’t work and there is no high speed fan. If those are your symptoms, It’s easy to replace yourself.
Thanks. I didn’t have a fan at any speed, though. Good to know.
My issue with mine was the relay; although the fan still worked.
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
Mine was a relay also. But everything worked except the AC compressor would not turn on.
After reseating all the fuses and relays, everything is working as it should. I can’t say any of them were obviously high in their socket, but nearly every one could be pressed a little deeper. So, I either fixed something or I’ll be dealing with an intermittent problem. (I hate the intermittent problems.)
Kinda like ED....sometimes things work...sometimes they dont....:giggle::giggle::giggle::oops:
