How to fix heater pipe leak?
Willem
Netherlands Antilles
2016 challenger Hellcat
I have a coolant like from heater line
See pictures below:
a view from endoscope camara where the leak is
Can this pipe o ring be replaced without removing the supercharger?
Absolutely allot of knowledgeable people here.
I cannot answer your question, but I know others here should be able to.
Welcome to the forum.
The metal coolant lines are bolted onto the back of the heads. It may be possible to pull it out enough to change an o ring but I would just remove the supercharger
Who
See pictures below:
Whoa..WTF..lotta work to replace an O ring...I remember the days where I wouldn;t think twice about tearin into a job like that...hmmm..wait a minute...maybe I cant remember that far back...:oops::oops::oops:
It has an o ring, replace it
It’s 1 simple bolt on the back of the head but the noise sensors or whatever are on the same stud. Disconnect battery, undo nut and change it. Put lots of rags under so coolant doesn’t get under the supercharger and sit in the valley
Who
Because probably never happened
