Guys, Check Your Faraday Key Fob Bags!
RetiredFirefighter
Metro
Durango
I bought one last year that only lasted about ~month before it stopped working (I forgot to take the FOB out of the bag and the door still opened).
So then I purchased a different brand that advertised "3 layers", and now that one stopped working after ~2 months.
That had me considering the GoDark Vault key Fob case. It's double the price of the pouch at $50 ea, getting away from the soft pouch design:
The GoDark Vault - Key Fob Faraday Cage
https://godarkbags.com/collections/...t-key-fob-faraday-cage?variant=44151447781589
But before I ordered it, I thought my keeping the keys attached to the FOB while it was in the pouch had possibly contributed to damaging the signal blocking liner.
So the bottom line is, I had an extra unused pouch that I will now test out without the keys attached. I'll keep you posted ...
I thought these bags were 'passive', how could it wear out or get 'used up' ??
Octanewide
House of power
Me too. It's a RFID blocker no batteries...
How many pockets do your pouches have?
I've seen many have 2 pockets and only the inner pocket may be lined.
22RENBS2 & 170
Alum foil works fine, and doesn't cost $50! :)
A friend used a metal Sucrets box.
That's what I use for my hat (Aluminum foil).
Works great.
Haven't been probed by aliens yet.
22RENBS2 & 170
Works great.
Make sure you ground the hat. I run a wire from the hat to the sole of my shoe. :)
Be extra careful in electrical storms.
MJS73
Moparland
2020 Challenger Hellcat
I think the Faraday leaks out.
22RENBS2 & 170
Yeah, those electromagnetic waves can be buggers!
Kinda like the damn blinker fluid😂
RetiredFirefighter
RetiredFirefighter
Metro
Durango
The fabric that blocks the key fob's signal from getting out of the bag ceases to perform its function.
As I stated in my post, I've now confirmed this twice with two different brands of Faraday key fob bags.
I'm guessing this occurs through the simple wear and tear of removing/replacing the key fob in the pouch multiple times a day.
Additionally, I've gone to the comments section where these bags are sold and I've found others reporting the same thing.
The two different brands of Faraday bags I purchased only had a single pocket. Good question though.
For a vehicle that cost ~$90k when new, I'd like to try and find something a little more technologically advanced. :geek:
I'm still looking ...
Works great.
and ............
That explains everything I needed to know. ;)
22RENBS2 & 170
Is there a retrofit kit where you can replace your fob with a key? :)
RetiredFirefighter
RetiredFirefighter
Metro
Durango
Yeah, the Zero Key Fob Kit is called "go buy a 1970 Hemi Cuda".:cool:
Loved, loved, loved my '94 Infiniti Q45t key, was made out of titanium & had a nice heft to it (stupid expensive to replace tho if you lost it !).
Nice! I would have assumed no heft, since it’s titanium… pretty sweet though.
Central
2022 Red/Red/Redeye
Easiest way to test the Faraday pouch: Put the keyfob in the pouch, get in the car with the pouch, and try to start it. If it starts, throw the pouch away. If you try to start the car and the dash says "Key not detected", the pouch is good.
Yes! The ones I use have two pockets, and only the inner one is shielded - I verified this through test - trying to start the car after I saw my wife using the outer one :oops:.
Since I like leaving the key in the car, should I carry a Faraday pouch just in case?
Cover your junk with it, that way there'll be no little Jimmy's running around your place snatching the vehicles when you're not looking !
MJS73
Moparland
In that case you're going to want to keep the whole car in a Faraday bag.
