Thread Starter #241
Thread Starter #242
Chipper Browns Chrysler. Look what's on the back window.
That is the top fuel car that I was a pit gopher for way back.
Haven't seen Chip in years, he was a partner in the car.
Brings back so many great memories.
Thread Starter #243
Thread Starter #244
Demonic Cat
Always liked and respected the T Bolt’s. Bobby Tasca helped develop it with Furd. Classic style, power to weight ratio 427 side oiler with teardrop hood.
Only factor racing Cars I liked better was of course our brand, the lightweight MOPAR’S. That gave them a big problem
ie: lightened factory race Hemi’s of that era. And now of course the 170
Original headlight ram air?
Demonic Cat
Yep that be it.
Thread Starter #249
Thread Starter #251
Just not sure if they were the first.
I think Pontiac used it in the real early 60s?
Thread Starter #252
Demonic Cat
Norm Krause place.
Demonic Cat
Blow off valve? Not sure, why would NA engine need one?
initial guess no
Demonic Cat
Based on picture ^^^ with many white hats, I would say Norm promoting the Dodge White hat Special for spring of 1969.
Thread Starter #256
initial guess no
If under certain circumstances too much pressure is created causing a backup in the carbs. A pressure relief valve type of deal.
The 6 pack cars had water drains which did the same thing.
Id think that’s built into the center section, that’s just meant to be a cold air intake like the hellcat air box basically or the redeye hood, just trying to direct cool air from outside. You shouldn’t have that much pressure from going fast
I need to do something because IATs at idle are hotter than stock with a JLT intake. I might have to come up with a different solution
Thread Starter #259
Thread Starter #260
Heat exchanger. Everyone says they don't work...I don't listen to everyone else.
