Hellcat AC Question
When running the AC on Auto, when I click into settings it always has air recirculation turned off.
Question, when AC is on Auto, does the system handle all those variables? When on Auto, if I change something it goes out of Auto to manual.
When in Auto, when I select air recirculation it doesn't go out of Auto. Just curious as I usually run air on recirculation the hotter it is outside and curious if recirculation is used when AC is on Auto?
Hope this makes sense?
I never looked but I would think that it would shift back and forth as needed. I never looked because my ac has always worked really well.
The AC works great, just curious on the air recirculation functionality when in Auto.
I never noticed what it does.
2fast4u
Edwardsburg
The recirculation just takes away the outside fresh air and "Recirculates" the air in the cabin. It is a manual function, possibly automatic when in Max a/c.
That is max ac when it recirculates.
2fast4u
Edwardsburg
You can also hit the recirculate button in regular a/c mode to run only cabin air...handy when it's a 100 outside.
Precisely. When I run AC through remote start (especially when hot) I noticed recirculation isn't always defaulted. I can certainly select it before driving off, but there seems to be no way to have it defaulted on Auto? No big deal...was just curious more than anything.
Max AC = recirculation.
Normal AC = no recirculation, outside air.
This is the only difference between the two.
just curious in that mode does it mean you keep smelling your farts over and over
Sounds like you need a good flush. 🤣🤣🤣🤣
probably so most here know im full of shit all the time just ask @Hickster
I hope you don't need therapy because of it?
Next ear youz bee needen 2 goes 2 a/c school. Then rally get screwed upster. Frum my latest under standenz. Said abuve, I do bee lieve.
Hit da auto bootune, it will have da dee sired temp, air flo, no knot da East side Flo, butt ster, fanny speed, and outside air mix turd. Hit da man uz ell, youz can addjust youz fan speed and temp yoself. Upturd whore down ward. I haz my Corevette shirt on, so Ize culd beeze wrong bye attire.Good luck, cause I'd can't figure my winderz out.
Its winter in Michigan, what is a/c:unsure:
It might, like a mike on a dog's ass, bee 80 bi Saturday. AC wider open, dare Davidster.
22RENBS2 & 170
Never knew any of this stuff. I just set the temp and hit the A/C button and everything is fine. But full disclosure, I do live up north.
