- Member ID
- #1308
- Messages
- 3,371
- Reactions
- 5,926
- Likes
- 302
- City
- memphis
- State
- TN
- Country
- United States
- Vehicle
- 2016 challenger hellcat
AS MOST KNOW I HAVE PUT MY CAT BACK TO STOCK ,STOCK MOTOR ,TRANS ,DRIVETRAIN ETC ,EVEN OEM T STAT ,ALSO 93 OCTANE ,,( ONLY EXCEPTION IS THE ACTIVE CHILLER I LEFT ON IT )
MY ISSUE IS WHEN IVE BEEN CRUISING FOR A PERIOD OF TIME AND IC TEMPS ARE 60 OR BELOW ,IT WILL SPUTTER VERY BADLY WHEN I FLOOR IT AND THEN ILL LET OFF FLOOR IT AGAIN AND NO ISSUES ,I DECICDED TO TEST IF IT WOULD DO IT IF I TURNED THE A/C OFF AND JUST LET THE IC TEMPS RUN 80 DGREES -PLUS NO PROBLEMS WHEN FLOORING IT ,,,,IM ASSUMING ITS CONDENSATION IN THE SUPERCHARGER AND ITS CAUSING THE SPUTTER
HAS ANYONE ELSE HAD THIS ISSUE AS WELL ,I WOULD ASSUME WITH E85 THIS WOULDNT BE AN ISSUE BECAUSE IT ALREADY HAS WATER CONTENT,SO I WOULD THINK ONLY PUMP GAS GUYS WOULD SEEE THIS ISSUE AS WELL ,PROBLEM IS IT MAY BE MISDIAGNOSED AS COIL OR PLUGS WHEN ITS ACTUALLY NOT
Moderator created Readability version:
As most know, I have put my Cat back to stock, stock motor, trans, drivetrain, etc. Even OEM T-stat, also 93 octane, (only exception is the active chiller I left on it)
My issue is when I've been cruising for a period of time and IC temps are 60 or below, it will sputter very badly when I floor it and then I'll let off and floor it again and no issues. I decided to test if it would do it if I turned the A/C off and just let the IC temps run 80 degrees-plus (sic) No problems when flooring it, I'm assuming it's condensation in the supercharger and it's causing the sputter.
Has anyone else had this issue as well? I would assume with E85 this wouldn't be an issue because it already has water content, so I would think only pump gas would see this issue as well, 'problem is it may be misdiagnosed as coil or plugs when it's actually not.
3
- Show All
