Okay, here are some numbers for you, as listed on the registrations/titles.
GT AWD: 4,088, with the optional spare tire.
'Cat: 4.353, with the dumb stereo where the spare should be.
Redeye: 4.357, w/o anything extra in the trunk.
All three are very similarly optioned, except as noted above, down to the color. If you're at 4,600 lbs. you must carry a lot more ammo than I do.
fwiw my redeye which is probably similarly optioned(no moonroof and Alpine stereo) weighed 4450 with 1/2 tank of gas on a local truck scale.
Could be proof of that blue cars are built with heavier matter.
My Charger came in at 4416. Full tank of gas and its loaded with sunroof, power stuff, etc. at Bradenton.
FYI - Very few scales are better than 1% accurate, and a lot are only 2%, or worse, especially larger scales.
~4400lbs * 2% = ~88lbs
So +/= 44lbs, or maybe +/= 22lbs if it's a really good scale.
Oh, and "repeatability" and accuracy are not the same thing.
It's the big balls that the drivers have ;)
Blue balls matter.
22RENBS2 & 170
Are you guys in the car when it's weighed? That could add a couple lbs. ;)
Weight is always without driver.
But a Charger/taxi should be weighed with passengers, right? And their luggage, maybe?
No weight is always with the driver. It is hard to compare times when 1 driver is 100 and another is 300. Its called race weight. Classes are weight with driver
No.
It depends on the event. If there's a weight limitation, then yes. Otherwise some events just want you to weigh in.
22RENBS2 & 170
I was in my car and just drove onto the scale.
Is that anything like "free calories"???
Driver pounds don't count?
22RENBS2 & 170
Does my Hellcat make me look fat???
thetalonguy
2017 Challenger HC M6
bennydodge
Thornton
At Bandimere with over a 1/2 tank of fuel
bennydodge
Thornton
