Need mopowar
Nitrous
  • No
    Votes: 3 42.9%
  • Raise Hell & praise Dale, Send it
    Votes: 4 57.1%
  • Total voters
    7
The spacer system is the expensive way to do it but works really nice. Also changing jetting is not easy with it
Im probably going to do a universal system
If you use a plate or a nozzle in the air intake system in a wet kit you will be
Not the way you should run it on our cars. The spacers with bars would be.
I will be putting a nozzle in the intake. It is cheap and well cheap power
dry
Wet is safer all around. Don't have to worry about tune not meeting demands.
I agree but if only doing 50-100 I would think it would be fine. Friends used to do more and seemed to work well. I'm not a nitrous guy at all but a fuel injected car should adjust to a point. Like when you drive your car on a 100 degree day and a 30 degree day
U
Thread Starter #32
Honestly dude! When is enough, enough?!:unsure::(
JK: April Fools
Never obviously lol
U
Thread Starter #33
Yeah I didn’t think about how big of a pain it’ll be to change jets with it
U
Thread Starter #34
Last outing on canned 112 octane e85 I was touching 69-70% IDC, so I don’t have much room left on my 1300s
U
Thread Starter #35
you don’t have really have to touch the tune at all for a wet system @jonx96 ? I guess that’s what I’m really trying to confirm. I’m torn between nitrous or snout and 108mm tb, depending on which system I go with it’ll cost the same. Car pulled 3 degrees of timing in the top end last time out due to iat, fighting an uphill battle without a chiller. Can’t do chiller and more power parts, so trying to figure out what would work best and not blow up my 60k mile sealed 2015 engine lol
U
Thread Starter #36
It’s always 100 degrees lol
My .02 cents
Work on maximizing your current setup. Once you can use all you got add more if you ne3d or just want.
Nitrous will always need a tune change if nothing more than taking a degree or two of timing out.
If I were going to use nitrous I'd follow my KISS philosophy and do a TB plate. Easy install and easy to adjust. I'm of the opinion a plate system isn't really needed until you're in to larger shots where cylinder dispersement becomes a problem. You'll be well below that on the stock motor and most don't live a long life on nitrous at more than 100 shot anyway. 50 to 75 is probably the sweet spot for cooling but I'm more conservative than some.
I’ll sell you fic 1650s and you can sell the 1300s.
Timing needs changed and depending where you are spraying maybe a few other things.
My .02 cents
Want a nitrious set if I get enough of us I can be a dealer 🤣
U
Thread Starter #40
Easier to tune than a dry shot?
