Fuel Rails
What does everyone recommend for fuel rails?
Is Fore the only choice?
You can't run the covers with the Fore rails?
Thanks
Remove the restrictions in your stock rails and supply line and they’ll flow just fine unless your using giant injectors like 1700’s or bigger.
Take a look at this
https://www.durangosrt.org/threads/stock-fuel-rails-why-they-don’t-keep-up.7748/
Last night finally was a good apples to apples comparison of same temp before and after these mods. I need to post results to this thread. Was 32F last night out doing 1/4 runs. Last year before these mods in 32F on corn I’d max out my pumps and injector DC would hit 90% and bypass valve would open. Last night at higher rpm and bigger cam pump finally hit 89% (which is 100%) and actual verse desired fuel pressure was 2 lbs shy but injector DC never went above 82%. This is with ID 1050X on dual 285 pumps on tested 85-87% corn in the tank at 32F. And one can keep their stock covers on!! Use of a bigger injector like a FIC1200 or 1400 or ID 1300’s and you’ll have plenty of fuel in the stock rails to feed them. And my fuel trims bank 1 to 2 are dead even now not offset 2-3% like they where before the modification.
I reposted your link. Don't know why but yours starts with durango and when I click on it it doesn't see me as being logged in on the site.
https://www.hellcatforum.org/threads/stock-fuel-rails-why-they-don’t-keep-up.7748/
I always wondered why the Durango was in there, I don’t have a Durango or visit that forum??
Thank you!!
I’ll put a conclusion post with a video clip of the log in the Fuel Rails post hopefully today or tonight.
D
Thank you for the information.
AlleyCat
Oro Valley
16 HC Challenger
Do you sell these? If I was going to fore what part numbers would I need?
Sorry, just saw you post. I don’t sell the fuel rails but I do modify ones that people send me. It’s $150 for the work plus return shipping of about $15. PM for more details if still interested.
@DavidKFla This is what I have installed on my 2015 Hellcat Charger. You could give HHP sales a call @ 1-888-894-1115 for anymore questions.
MOPAR 2.4L IHI Hellcat Fuel Rails with Pressure Sensor & Drain Valve for 15-Current Challenger, Charger & Ram TRX 6.2L
MOPAR Hellcat Fuel Rails With Pressure Sensor & Drain Valve for 2015+ 2.4L IHI Supercharged Hellcat Challenger, Charger & Ram TRX - 68170299AE
https://highhorseperformance.com/
Also you can include in your purchase a Drain Line.
Product Description
EM Hellcat Fuel Rail with Pressure Sensor. This fuel line comes with a Schrader valve on the drivers-side rail which allows for easy fuel draining for customers wanting to change fuel. We also sell the additional EZ Drain Line separately for easy draining
This rail does not fit Jeep Trackhawk or any of the 2.7L IHI vehicles such as the Demon and Redeye.
Linda :)
D
Product Description
Linda :)
Doesn't my Charger already have these?
These are aftermarket ones that allow you to drain the Fuel
On the fuel pump relay in the trunk fuse box you can jump pins 30 and 87 with a jumper wire.
