More vehicular idiocy
Too much to comment on. Other than to say the Russians and the Chinese are some crazy red-neck sonsabitches. View it, or don't.
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
That's what Communism does to your brain.
I don't think that last guy survived
stonewall
Conway
AR
I need to watch more later. Saw the guy watering the gas flames with water, saw a water truck fall apart, never seen anyone run a backhoe with so much ineptitude and roll it. The rest of it should be excellent. That was a good start, Mag! Nice.
Demonic Cat
Those are the batshit crazy people doing absolutely insane things that force over regulated stuff on the rest of the world. Must admit I had some laughs and wow came to mind several times.
Whatknot
OR
Well now we know how to seat the bead on a tractor tire.
And remove exterior cladding in a high rise ......
Forest Gump said it best - Stupid is Stupid does. :LOL:
Demonic Cat
Reseated a tire that bead came off wheel on tractor or back hoe over the years. Take starter fluid spray 4 or 5 seconds. Stand behind wheel direction off rolling. “Do not stand in front of bead” light with pole like video. Might not even have to add pressure once inflated Yes I was batshit crazy once.
safer way is take ratcheting binder/tie down, wrap all the way around center of tire and and compress center forcing outer beads to seat while adding air from “remote valve stem chuck with long lead“ until seated, remove remote chuck lead, now finish filling to recommended pressure.
Think about how much energy is sitting on the gas station quick mart shelf when you see a few cans off starter fluid. Just 4 or 5 seconds of spray can seat a bead that is on my large agricultural tractor tire or back hoe.
Batshit crazy no more.
