MFER-1 mod is plenty loud. No need for exhaust upgrade. Maybe some ear plugs though lol
Inrfire
Omaha
NE
Did the Mfer-1 and I like it. But I never thought it would be so loud. It seems like my car has gotten louder just after the first few hundred miles. I do love it, but my ears sometimes almost want ear plugs. For me it is plenty. I will not be needing a mid pipe or anything else at this time.
Has anyone else modded their valves open, and if so! What say you! The car really turns heads now. I would say mostly with positive effects! The quality of these were very exact. Holes lined up tight, and the stop tabs fit in tight, to where the valves in the open mode had no play at the 2 o'clock open position where it keeps them fixed! RcI8VsRHR9azXm0d8TD9VQ.jpg
DFW_Redeye
Dallas
2019 Hellcat Redeye Widebody
the drone inside the cabin? I’ve been tempted especially since the 2019’s can just be wired open without the need for a Mfer but I’m scared I will drown out my expensive HK stereo :ROFLMAO:
Inrfire
Inrfire
Omaha
NE
Yes, I had these ordered and someone told me about just wiring them up with no codes. I actually think you told me but I may be wrong! I used them since I had them. There is some drone. I don't have any stereo upgrade, but my blue fang, aka tooth, might be a bit harder to use at certain speeds.
I am a musician and one would think loud noise wouldn't matter. But it does to this cat. I guess the nice thing is if I get sick of it, its a 15 min reversal. I like to think I am Randy Probst when I step on it lol
Av8ing1
San Marcos
2019 Charger Hellcat
Interested, someone please explain the "wiring them up with no codes."
Inrfire
Inrfire
Omaha
NE
I believe the spring is pulled off of the back of the unit, the valves are wired open, the units bolted back on and the units left plugged in.
Than when the car starts it cycles through the unit without throwing a code on the Redeye. The actuator is not turning any valve since the spring is removed and the rotation of the internal hub tricks the unit. I am sure someone can explain it better than me!
motorhead
Ottawa
2019 Challenger HC Widebody
Proud American
2016 Hellcat Challenger
You pretty much nailed it.
Av8ing1
San Marcos
Thank you for the link! I didn't see a ton of consensus that it works on all models or doesn't have any long term detriment (like the actuator motors always turning until they wear out.) Might give it a try though when I get a chance, whats the worst that could happen! (y)
Markp
Fuck Trudeau
Inrfire
Inrfire
Omaha
NE
Like you said, just pull one and remote start the car and see what it does. Probably they over shoot the stops just a bit each way and the springs act as the cushion when it bottoms out from torque with the valve stopping in either direction. That way it keeps things tight for the valves on the open and shut side and doesn't over stress the motor with the spring in there.
Just turn the HK up. 900 watts there. Have plenty.
Yup I posted that on Hellcat,org. You do not need MFERS on 2019 it will not throw codes.
Thx you just saved me some money.
I’d like to see how you wired the valve open.
Markp
Fuck Trudeau
I have not done mine yet. You just have to use a wire to hold it at full open.
Inrfire
Inrfire
Omaha
NE
Just drill a couple little holes on the flange where you need to and run a tie wire in and out holding it against the 2 o'clock position stop! Or come out of the bottom big hole like he did and find a spot somewhere else.
There may be room to just put a hose clamp over it and hold the outter and inner flange. Than use no wires!
Going to do mine on my Redeye later tonight or tomorrow.
Inrfire
Inrfire
Omaha
NE
Have fun, you will love it!
I already have it done in a tune on my 2015 Hellcat. Which also has Dyno Max Mini Race mufflers and it sounds bad ass.
Inrfire
Inrfire
Omaha
NE
Thread Starter #19
I already have it done in a tune on my 2015 Hellcat. Which also Dyno Max Mini Race mufflers and it sounds bad ass.
Thats awesome!
Markp
Fuck Trudeau
Awesome! Please post up how the mod went and how it sounds.
