Okay to drive the car to the paint shop with no supercharger coolant?
I see some say drive it, others don't. Like many things, do what you are comfortable doing:)
MurderCat
MurderCat
Rochester
Thread Starter #23
Don't know why I didn't think of this yesterday. My AAA membership would cover the tow to and back :) 4 weeks from now she's going in to get put to new exterior/trim wise. Hopefully trim repairs and paint isn't too bad so there's room in the race car budget this season. Next up is a 15" conversion with Carlyle racings billet knuckle no grind kit.
Feel much better using AAA's flatbeds than some random guy on Uship for a couple hundred going 10 miles.
I agree....cooler denser air is always more efficient....hands down.
But roots blowers themselves are much more efficient than they used to be - even without an intercooler. Instead of the old lobe-type rotors, most blowers now have semi-helix rotors that don't heat up the air near as much as older blowers did in the day. The Magnuson MP-122 that I have on my old Camaro doesn't have an intercooler, but I'm only spinning it hard enough for 7-8 pounds of boost.....still adds plenty of power..
And as mentioned by @vortecd, the Vortec centrifugal blowers are even more efficient and most of their kits don't come with an intercooler.......but having one is always better....
-And to the OP....good call. I wouldn't drive it either without the intercooler working either. Not worth the risk, and not tuned for running like that.
Agreed. Look at the old MP-112 (with only four lbs and intercooled) not high-helix, but still yielded over 150 crank horse power and torque. Simple bolt on installation. And respectable even then, but not nearly as efficient particularly for something like road racing as todays set up. All I'm saying is I wouldn't go without a charge air cooling set up if I could possibly avoid it. A buddy on here went all NA with the same motor and got the same power level but I believe he once told me he'd go the supercharger route in the future because it was less trouble.
my point was you can make power without an intercooler
And with this I highly agree. My point was the addition is so simple I'd not leave it out. Gotta cool that nicely compressed / accelerated charge air to get the most out of it - or someone will be knocking at your door sooner, so to speak.
EDIT: for clarity
Xylander
Tallahassee
You can also make power with a Litens pulley and stock injectors. But why on Earth would you do such a thing?
problem solved
Maybe to just get it to a tuner and then change out the injectors. You could put the smallest pulley possible our our cars and if you stay out of boost could drive it anywhere. Same without an intercooler, will not hurt anything to get it from A to B if you are smart about it
