Touch-Up Paint Code for OEM "Slingshot" Wheels
Prange
no longer in Chicago
2021 Charger Scat Pack
I'm looking for the touch-up paint code for my '21 Scat Pack Dynamic 9.5" wheels. Can anyone here help me with this? I've called three parts depts. to no avail.
Thanks.
If those are the same color as the Hellcat slingshot wheels (sort of a satin black), then I found Mopar code PXF is a pretty good match.
Also, if they are just small sand chips or thin scratches the old detailers 'sharpie pen touch-up' trick works well.
Not perfect & won't last forever, but makes the spots very difficult to see unless you are really looking hard.
P
Prange
Thanks. I should've specified that they are the satin black, not the Brass Monkeys.
P
Prange
Or the dynamics wheels might be known as Black noise?
Subscribed for the paint codes!
Awesome, thank you!
I have found that to work good,,, the sharpy. But if like me. having Vetts and Z28s with soft aluminum, I took out an extended warranty on the car and one on the wheels and tires. I have used it many of times and the dealership hates to hear that one. In a hurry or ina pinch the Sharpy works good, touch up paint worked better but the replacement of the wheels works better. I will take out another on the next car.
P
Prange
I also took out the wheel/tire warrantee. Factory Mopar- 7 year/100,000miles. Same as for the car.
P
Prange
Dodge is just calling them "black painted".
why2kmax
12 Second Best E/T
Shrewsbury
maybe try Testors Semi-Gloss Black #1139-RM11391_0611 Its almost a direct match for the satin black hood, might be good on the wheels as well.
