Ice Box
ostmike
Portersville
2015 Hellcat
In the tune it has an enable or disable tab just curious , I’ll try the other things you mentioned as well thanks 🙏
I believe the disable tab you are referring to only indicates if the vehicle is equipped with a coolant pump. On your platform it is probably meaningless. The minimum/default rpm and coolant temp I believe are the key. However, I have not tested this.
First off don't assume I am an expert at anything other than wasting time :)
I have never disabled a pump so I do not know the answer to that. I assume you set the min ECT enable temp to 376, Disable RPM to 0 and all the appropriate tables to 0 rpm? That's where I would start if I was attempting to disble the pump.
Can’t you just unplug it?
This is the new age thing gym we do everything through software we don’t unplug shit anymore😂
ostmike
Portersville
2015 Hellcat
Not unless you want a CEL. Unfortunately almost anything you unplug generates a CEL these days which can be a good thing (if you accidentally left something unplugged or not plugged in all the way) as well as an annoyance.
This is way above my head. Guess I’ll head back to the little boys room.☹️
Light is ok at the track when using pump in ice box
Thread Starter #27
Ended up going over the subframe. Didn’t have to go one exhaust
A43AB590-5743-413F-91CC-6E47D659AE23.jpeg 6D3A8BDA-2C78-48EB-9A04-F3D45E5D6BA5.jpeg
