Any tricks to getting Clutch Hydraulic line clip in place at trans??
Eustis
2015 Challenger SRT/70RR
Having a difficult time installing the Hydraulic line clutch clip at Trans. Just doesn't want to clip into place. Any tricks to this??
thetalonguy
2017 Challenger HC M6
I remember it took me a long time to get that sucker back on. I think I took long needle nose pliers to hold the clip in place with one hand and then used my other hand to push the clip on. I was doing this on jack stands in my driveway and was terrified the clip was going to fling out and be lost or drop in the trans tunnel hole (I might've put masking tape over the hole to prevent that). I took my sweet ass time to make sure I didn't lose or bend that sucker.
Use youall petrafied doll fin penis.
Fabman
Eustis
Fabman
Eustis
Yep ! first attempt it dropped in the bell housing...but I was able to retrieve it with a magnet...THEN the masking tape went on. But still cant get it into the grove on the other side of the receiver. Gonna hit it again this morning...,,,
I think you maybe putting it on wrong? It doesn’t go through the holes s as bd out the other side it goes around them then some have white plastic cap to insure clip can not come out. I’ll see if I can find a picture.
Here ya go, and BTW, the little blue X device is not the clutch delay valve. It is a restrictor to limit speed both in and out, the black device controls flow as well but allows full flow forward and restricts on the return, it’s called a flow check valve. It’s located under the brake booster where the clutch line comes through the firewall.
IMG_8994.png IMG_9541.png IMG_9476.jpeg IMG_9474.jpeg IMG_9540.png IMG_2478.jpeg
The guts can be removed from the black item, and put back in as well. I have Draggy data that shows faster shifts with it gutted. I’ll post if I get time to look for them. I’ve posted this all before if anyone what’s to search my posts to find it, has draggy data and all.
Fabman
Eustis
HA ! THATS IT ! I was trying to pu it INSIDE the grove...not around the outside . THANK YOU !
Here’s the guts from inside the black item which is the true Clutch Delay Valve. It’s very easy to take apart and clutch action difference is noticeable when gutted.
Ths
View attachment 120370 View attachment 120371 View attachment 120372 View attachment 120373 View attachment 120374 View attachment 120375
t doohickey plugs into the slave cylinder right?
Hmm, maybe not. Mine got deleted when went to a ram clutch triple
The black thing? That’s under the brake booster
