Can I Actually Purchase This 3.0 IHI?
Same, as long as you’re not going all out e65-75 Is all you need. I have 2 tunes, no big deal. Realized it was a pipe dream, and now dodge actually has it in the os, which is why I’m eager to see how it works and if HP tuners even has the tables for it specd out yet. If you can scale the voltage, you might be able to bench flash your pcm (year dependent) with the 170 os and your vin, pin an off the shelf flex fuel sensor in and change the scale of the voltage in the tune. But this isn’t something that just anyone will be able to do with any tuner, will 100% need to be bench flashed. Unless hp tuners uncovers it existed in the old OSs all along, but I highly, highly doubt that
For most that will be handy. But for me no need. But if I can help in some way I will. Todd gets he’s 170 in the next week or two I will have him pull the sole and send to me
Awesome man! I appreciate it. Like I said, more curious than anything. Not really worth it to do anything with. I run pump e85 and have for 5 years, not a drop of gasoline, test every now and then, it’s no big deal
When I went 7.30 in my Buick it was off pump e85 did not have all this rave mix back than
2ndgen
Orem
I know exactly how they do it, and it’s not right. I figured it out. They enable the exhaust recirculation valve in the pcm (6.2 doesn’t have it), run a wire from the flex fuel sensor to that pin on the pcm (same pcm between 6.4/6.2) rescale the sensor and voltage to mean a specific e%, and then modify the exhaust recirculation tables. Which don’t have cold start tables, and a lot of others. It’s a good try, but all the tables aren’t there to make it work 100% the way it should
Interesting! So, it's not a 100% perfect solution--but you gotta admit: That is /damn clever/.
Yep. It is, I give it to them for ingenuity for sure - just not all there unfortunately. You have to work with what you got with these cars unless going full standalone, so repurposing things is the name of the game
Whatever they ship with the C170 as far as PCM goes should be interesting as well.
I'm betting it's the same GPEC2 the 2018 and up have or the new one if it's been changed since 2018.
I doubt they'd one off a PCM for 3300 cars.
Then again they basically one-offed a 240mm rear axle for these cars.
I say that because at this pace it'll never be available in the DC catalog.
2ndgen
Orem
Still waiting for one of the new D170 owners to do a teardown of the rear end and show us all what's changed...
#50
I bet you'll be waiting a long time.
2ndgen
Orem
Nah. I bet someone wrecks one in the next few months. There's always someone.
Doesn’t have to be a one off, just needs to work. They made them for 3300 cars already, if they want to sell C170 crate motors they need to send PCMs with them.
There is a PCM for the Hellcrate, this will be no different.
Facebook
AJ Berge (Hemituner AJ)
Fresh off the assembly line we have c170 Hellephants! All 3.0 IHI Superchargers are for sale $10.500 shipped !!
$10 bucks? Sold. People like that are gonna buy them up and sell at a markup. Ridiculous
Interesting the crate c170 has the flex fuel sensor. So where’s the engine management kit for these?!?!
DemonSRT
Kawartha Lakes
#56
The $10,500 is for the IHI only.
This is literally the only portion of this car I care about minus the driveline.
GIMME. DAT. SENSOR. SHIZ.
No way that’s a c170 crate. Engine harness and everything is sold separately. And this block is yellow. This is a 170 replacement block or he pulled it from a 170
DemonSRT
Kawartha Lakes
#59
If you order these engines from Mopar and not threw Direct Connection then they do came just as you see it in the picture with the engine harness as well. These are known as warranty crate engines
Good to know. So then it’s just a warranty replacement demon 170 engine and not the c170 crate engine
