What would cause idle to fluctuate in park?
AlleyCat
Oro Valley
16 HC Challenger
When the car warms up the idle in park goes up and down. If I switch her to drive within 2 seconds it evens out. Is that tune related or something else?
Frenchcat
t-r
Well with all your mods:eek:personally I would be happy to have only this small inconvenience that must come from the cam installed. Wow your cat must be a real bomb.
motorhead
Ottawa
2019 Challenger HC Widebody
Running idle airflow in park isn't tuned properly, when you drop it in Drive the load and transmission dampen the pulses. Any decent tuner can address this.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
your car looks very sharp in the white widebody. the flares blend in with the lighter color. i used to tune raf on my old pontiac g8.
WHATS THE VACCUUM GAUGE READING ? BOOST GAUGE SHOULD TELL YOU
motorhead
Ottawa
Thanks! And I believe FCA uses the terms derivative and expected under the idle airflow section of the tune. I'll have to confirm later tonight.
