TRACKHAWK INTERCHILLER
Trader history for TrekGTO (0)
ST PETERSBURG
05 Maggie GTO
Active Interchiller is the original Chiller that developed Competition Mode and Automatic HX Bypass in 2009. We have the only Progressive Refrigerant Distribution Device in every core and CNC Refrigerant Adapters for a no AC hose cut installation.
2011+ Grand Cherokee & Trackhawk
We supply modified New OEM Liquid Line, Competition Valve, wiring harness, relay, 10' insulated hose, switch and LED for the only true Plug N Play Hellcat Interchiller Kits. Our Programmable Automatic HX Bypass upgrade is compatible with any pump and allows you to retain your HX. We provide you a measured amount specification for refrigerant that is less than 2lb system total due to our 2 fitted refrigerant hose no-cut design.
Competition Refrigerant Adapters
No HX bypass $1299
Automatic Digital HX
Bypass Upgrade $150
Stage 2 Upgrade $549
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thread Starter #2
Trackhawk & Hellcat 19” Competition Xtreme Chiller in Stock and Shipping.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Trackhawk 19” Competition Xtreme Chiller -12 with Digital High Volume HX Bypass for Justin in CA. 100% bolt-on nothing cut, complete kit.
Keep waving that GTO flag. Think we talked years ago. Good on you with the chillers.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thanks, Mitchell in IA with this beautiful Spice 06 GTO Monaro conversion just fitted our 19” Competition Xtreme Chiller with High Volume HX Bypass. He said our GTO kit was amazing.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Trackhawk 19” Competition Xtreme Chiller -12 no HX Bypass for Larry in NY. 100% bolt-on nothing cut, complete Interchiller kit.
Nice kits!!
You make a kit for a 16 Challenger Hellcat? What about bracket for mounting the heat exchanger, that come in kits too??
While asking what about 17 Mustang GT as well?
TrekGTO
ST PETERSBURG
05 Maggie GTO
Nice kits!!
Direct fit Interchiller kits were added in 2011 for all Charger and Challenger, mounting brackets included where needed, No to new Mustang other than universal.
That makes me like you already.:LOL:
Can you post or PM me a price for complete kit including bypass valve for radiator
TrekGTO
ST PETERSBURG
05 Maggie GTO
2014 Jeep SRT Whipple 19” Competition Xtreme Chiller with Digital High Volume HX Bypass for Daniel in San Juan, PR. 100% bolt-on nothing cut, complete kit.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Retaining the Whipple HX on 2014 Jeep SRT Interchiller.
Blown7
Woodstock
2018 Trackhawk
Hey there mr TrecGTO
Not much interaction fron from the website....
Maybe you send me a kit and I report the true numbers of your chiller...
Lots of options out there ..of which your company is one.
do you also support the chiller button push? Where I can cool the engine between runs?
ellenton
2016 mango hellcat challenger
Here's where the Interchiller kit is far better than any other kit out there; it is truly a plug and play kit with manufactured hard lines. There is no cutting your factory parts, you don't have to splice lines, or use worm gears or crappy connectors, you get the hard lines already with the proper bungs welded to them. I have told Dave he needs to show more of how these parts look, they are truly works of art.
Now to ask whether his kit supports the chiller button push means you either don't know what its called or haven't done your research. My car I leave idling in the pits and the IC temps drop to under 50 degrees, and my IATs are at ambient.
You can purchase any kit and make it work - but there is no other kit that will come with all the lines pre-made to fit your car. Also, Dave's kit is the original chiller kit - and the care that goes into each kit is clearly visible with the quality and craftsmanship.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Limited Time: add any bumper tank/chiller mount, ice tank/reservoir to our Xtreme Chiller and receive Free Shipping on said ice tank/reservoir. All Trackhawk, Grand Cherokee ***
TrekGTO
ST PETERSBURG
05 Maggie GTO
  • Remote reservoir front bumper replacement that also mounts our Interchiller, works with your IC reservoir and makes our Interchiller 100% bolt-on with or without HX bypass. San ice.
  • Battery replacement reservoir/ice tank 100% bolt-on. (replaces front battery and relocate battery to trunk)
  • Ice tank for trunk mount (for use with or without ice)
  • Black insulation sheet to insulate against heat and condensation. Also helps reduce coolant temperature. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ (requires your spray adhesive)
  • Black insulation sheet to insulate against heat and condensation. Also helps reduce IAT. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ ( With Pressure-Sensitive Adhesive )
  • 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 3+
  • 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps IAT. Unslit, -70*f to 220*f, R-Value 3+ 1.75"od
  • 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 7+ 2"od
  • 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Unslit, -70*f to 220*f, R-Value 7+ 2"od
  • 2x AN-6 90-degree push lock style for rubber hose
  • 2x AN-12 90-degree push lock style for rubber hose
  • 2x AN-16 90-degree push lock style for rubber hose
TrekGTO
ST PETERSBURG
05 Maggie GTO
The only true plug n play, only nothing cut, only automatic HX bypass, only complete with wiring, only one with a true money-back guarantee, If you're not happy get a refund and keep the kit. No Ice Guarantee
We have a $1000 reward offered to any Chiller manufacture that is colder at 1/4 - 1 mile finish line with any size ice tank up to 8gal and stock HX no ice. No takers so far. 2021 no ice reward!
We are looking for Mustang, Mercedes to prototype Bumper reservoir and Chiller kits 100% bolt-on If you're not happy get a refund and keep the kit
