- Member ID
- #993
- Messages
- 3,506
- Reactions
- 11,295
- Likes
- 302
- City
- St. George
- State
- UT
- Country
- United States
- Vehicle
- 2016 Dodge Challenger Hellcat
- HFCOTM
- View Images
This is the hot setup for keeping your Intake Air Temps under control at the track. This is out of my car because I had to switch to the side mount version to make room for a fuel cell in its place. It has the 40 gpm Davies Craig water pump (the one you want). This setup retails now from EMP for $649. I covered the sides and bottom with a couple layers of thermal barrier. That helps keep the cold cold in a hot trunk space. When using this setup, you bypass (or remove) your OEM intercooler pump. Don’t need it with this Davies Craig bad boy. The heater hose that is used to plumb this from the trunk and back is not included. It is extra from EMP and you can simply purchase that from ACE Hardware for less. I’ll take $400 ($250 discount from new). Shipping will be at cost.
- Show All
