Snout price
How much are used snouts with no issues going for these days? No pulley
I have seen 2.4 snouts for a couple hundred. 2.7s much more
2.4 snouts used to go for around $500. That no longer the case? Torn between just getting an sdg snout or full port
Wizza
Stafford
VA
2015 Dodge Charger Hellcat
I would recommend going the SDG route, if mine failed again it is going in the trash
The original inner diameter design is much better design than trying to neck down the oem and it easily runs the larger tb
I replaced my bushings last December and swear if the bearing on this thing fail a third time in 3 years I am killing it with fire
I want to say SDG has never actually seen any failed bearings on the bearing plate side. The bearings on your snout keep failing? Want to buy mine? 😅
I wouldn’t be going with the bearing plate, just the snout if I went with SDG. Not trying to spend $400 on shipping. Sdg will only install the bearing plate, not ship it out
Trackhawk, RS3, Golf R
They are kinda noisy after ported. The sound is normal to anyone who has a clue but to others it sounds like ur bearings need to be replaced but the sound is perfectly normal its just a harmonic rattle and goes away when making power. Mine was ported at Kong my buddys at Jokerz they both make the same sound.
Sdg is a no brainer on the snout
Octanewide
House of power
Anyone have the part number for the stock 2.4 snout?
Wizza
Stafford
VA
$700 and you can have mine, 2018 with the better bearings
