End of an ERA - Hellcat package discounted
Martin
2018 Dodge Challenger Hellcat
After much thought I have decided it was time to discount the Hellcat platform Performance Pack 1s. These are pretty much for your stock tune only guys. These packages still add a good amount of power and if you are an automatic much better shifts. Since this is truly the end of an era I figured it was time to start dropping price on some of these kits that RND has already been done over the last few years. I hope this encourages a few people who have been on the fence that they will start tuning their vehicles.
From what I can see there packs are significantly cheaper than others. Heck these kits have been so tested Performance Pack 1 Redeye owners have been in the 9s many time. Some as fast as 9.4 with just an injector and e85 upgrade and 9.6 stock injectors and race fuels. These kits have been significantly tested and I am almost surprised I am deciding to do this. There is no end date on this sale for now. If these kits keep selling well the discount will stay applied.
https://mooredperformance.com/products/2018-hellcat-performance-pack-1?variant=49925798986031
https://mooredperformance.com/products/2015-2017-hellcat-performance-pack-1 - Under $1000 if you are a manual !!
https://mooredperformance.com/products/redeye-stage-1
Very, very tempting - not having a trustworthy shop anywhere near here is saving me $$ but costing me fun ....................
Trustworthy shop in North East Pa if you are close?
I'm in west/central FL ...............
I know a guy in north Florida that works on hellcats predominantly, zip 32043. Can dyno tune as well. Been trying to get Jon hooked up with him for a while now. Close to you?
Martin
On your 2016 the only actual physical work is removing the pcm. I have a shop in Largo and Tampa that can both assist you if need be with any of the packages. Plus the shop goman is reffering to as well would be trust worthy.
That's almost to J'ville, minimum of a 2.5 to 3 hr drive. I know there are places on the east coast and probably in Orlando as well, but if there is an issue it's a long way to have to go (or get the car flatbed-ed) to have it looked at.
On your 2016 the only actual physical work is removing the pcm. I have a shop in Largo and Tampa that can both assist you if need be with any of the packages. Plus the shop goman is referring to as well would be trust worthy.
Largo is also 2.5+ hours away (ironically, I lived there for a long time many moons ago). Tampa may be doable depending on where exactly they are.
I did watch Speedy's vid on removing the PCM and there's no way I'd get that out of there with my stubby, sausage, partially working fingers - 'golden years' my ass !!! Also, I thought there was some sort of security bypass cable that had to be installed or was that for later years ?
Who's in North East....That;s just 70 miles from me
JP426
Walla Walla
Very tempting! What else would be needed, such as HP Tuners etc? I believe I am mechanically inclined enough to remove my PCM. I'm sure there's a video somewhere!
Shop I dyno at and Jon has worked with too doing remote tunes, C-pops, link below. Depending on work you want done Chris the owner can handle or you can get me involved to do the work.
Link only provided below info
C-Pop's Auto Shop
(570) 855-4002
Not for the faint of heart, there’s 3 bolts you have to undo from the very top, very easy to get to part of the car 😬 😉. Take wipers off (2 nuts), cowl off (all clips/just pull), top bolt on bracket securing pcm/bracket to shock tower brace, 2 more bolts securing pcm to bracket. I undo the top bolt, pull the bracket with the pcm up to easily get to the others. 15 minute job if you take your time
I have one of his first tunes for my Redeye. Several know my story, it has been an amazing success, from the improved power and shifting, no gear shift bog or hiccups to a very happy and cooler engine that I can trust again on the road courses. On the street, it is the hot rod it should be. Basically impossible to go WOT unless you like jail or moving very unsafely fast! The choice for me was sell it or allow Jon to fix it two years ago. It is “fixed”.
Thanks @Jon-MooredPerformanceLLC.
Th
C-Pop's Auto Shop
(570) 855-4002
Thanks so much...will reach out (y)
Bowlerguy92
Paging @2ndAmend to take a walk on the wild (and now discounted) side
Martin
I think you might be pulling the pcm the wrong way
This:
Pulling the wipers and cowl seems a bit invasive, maybe it's easier than it looks.
