Challenger Kill Switch
Trader history for AllthingsMopar (0)
AllthingsMopar
OLIVE BRANCH
2016 Ram
A solution that is plug 'n play which allows you to select the hidden location(s) for your vehicles kill switch. No cutting into your factory wiring harness is needed.
How it works: Once you flip your hidden kill switch(s) to the OFF position your push to start run button no longer works. The solution retains remote start feature if equipped, but adds a deterrent for would be thieves to take your vehicle with one or more kill switch options. Only you know where the hidden kill switch(s) are located and if in the OFF position you can NOT use your push button start to go to the RUN position after you remote start it with your FOB. But once you flip your kill switch(s) to ON, your RUN push button operates as normal.
Theft deterrent: Thieves that break in and add their own new key FOB to your car are also deterred as the push to start button will not work for them either while kill switch(s) are in the OFF position.
How long to install? Most will spend more time figuring out where you want to hide the kill switches than it takes to install tbh. Great deterrence solution to add to your protection efforts in keeping your car from being stolen. Check out the high level install instructions HERE.
Works on multiple models of Chrysler, Dodge, Jeep and Ram Trucks - check out the site for details.
Multiple options for you vehicle needs. Add what you need to install how you want it on your vehicle! Items such as crimpled and heat shrunk blade connectors as well as toggle switch options to add in addition to your harness. Or order the harness bare so you can solder in the switch you want, or we have a toggle switch with leads that is ready to solder in as well. Lot's of options!
We also have a 2 switch harness solution with optional lengths for each harness lead to each switch ranging in 2, 3, 4, 5, and up to 10ft lengths. Each leg can be a different length! Your car, you chose the length on where you have chosen to hide the kill switches!
USPS Shipping from zip 38654
JW² Innovations - For those interested in learning more or to place an order - please checkout our site at: jw2innovations.com, or via email at [email protected]
Below is a picture of our No Splice Kill Switch Harness with a 2ft length for the kill switch. All options above available to add, or if you need it longer options in 2, 3, 4, 5, and up to10ft lengths.
Nice how much? 3ft version
A
AllthingsMopar
OLIVE BRANCH
2016 Ram
A 3ft kill switch harness with standard wiring is on sale right now for $33.74 here LINK - kits are on sale for $38.69 here LINK
There are many more options including a 2 kill switch in various lengths, a fake OBD2 harness, more kits that include the switches, and more on the website HERE
Link to Challenger harness offerings HERE
Trackhawk, RS3, Golf R
Kool..... an ounce of prevention is worth a pound of cure!
