My layin on the floor days are over...I set the car about 4'...I have a comfy chair on wheels..(I can slide around anywhere...high intensity headband light...put on the surround sound...I can stay out there for hours...
Don't forget to leave "open spots" for the lift when routing the tubing for the floor heat.
I had 2x2x2 foot "blocks" poured in the floor where the lift would go. Unfortunately the contractor's drawing was off by a foot, so sure enough, I drilled into the Pex on the third hole.
Thanks Jimmy, but no floor heat except in the master bathroom per the lady’s list. Certainly would never think of floor heat in a garage area. That is shit for inefficient compared to simple (read comparatively no brainer - INEXPENSIVE) forced air in that leaky airspace no matter how good you think you are.
Sure feel better today. Been doing just that. Got done with that bottom body detailing on a chair. I need to replace some wraps (the rear flairs) and that some of that battered gray bottom trim this year. About to get right after the All-in-One Ceramic. The car was not driven or washed enough last year to have anything that needs corrected that I can see yet. Maybe I’ll do the hood and around it when I take a good look at it.
