Limited Time: add any ice tank/reservoir to our Xtreme Chiller and receive FREE SHIPPING on said ice tank/reservoir. All Hellcat, All Demon, All W2A
Trader history for TrekGTO (0)
ST PETERSBURG
05 Maggie GTO
  • Remote reservoir front bumper replacement that also mounts our Interchiller, works with your IC reservoir and makes our Interchiller 100% bolt-on with or without HX bypass. San ice.
  • Battery replacement reservoir/ice tank 100% bolton. (replaces front battery and relocate battery to trunk)
  • Ice tank for trunk mount (for use with or without ice)
  • Black insulation sheet to insulate against heat and condensation. Also helps reduce coolant temperature. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ (requires your spray adhesive)
  • Black insulation sheet to insulate against heat and condensation. Also helps reduce IAT. 36"x48"x1/2" -300*f to 250*f R-Value 2.0+ ( With Pressure-Sensitive Adhesive )
  • 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 3+ 1.75od
  • 3/4"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps IAT. Unslit, -70*f to 220*f, R-Value 3+ 1.75"od
  • 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Pre-slit/pre-glued with over flap. -70*f to 220*f, R-Value 7+ 2"od
  • 1"x6' Black insulation for pipe/hose to insulate against heat and condensation. Also helps reduce IAT. Unslit, -70*f to 220*f, R-Value 7+ 2"od
  • 2x AN-6 90-degree push lock style for rubber hose
  • 2x AN-12 90-degree push lock style for rubber hose
  • 2x AN-16 90-degree push lock style for rubber hose
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thread Starter #2
Any pics on Hellcat install ?
TrekGTO
ST PETERSBURG
05 Maggie GTO
2.5 to 3 gal bumper replacement reservoir and universal tank with bleed port and installation kit GROUP BUY we need 5 each to make it happen.
Orders will be updated daily prepayment required with shipping starting 1/18
Bumper Reservoir $350 free shipping regular $400
Not pictured is the Chiller mounting integrated into reservoir*
Universal Reservoir $250 Free shipping regular $300
See chiller mounting below***
Don't forget insulation
updates daily
https://www.facebook.com/Interchiller
TrekGTO
ST PETERSBURG
05 Maggie GTO
Bumper mount cut to fit reservoir no Chiller and 2+gal bumper with integrated Chiller!
TrekGTO
ST PETERSBURG
05 Maggie GTO
The only true plug n play, only nothing cut, only automatic HX bypass, only complete with wiring, only one with a true money-back guarantee, If you're not happy get a refund and keep the kit. No Ice Guarantee
We have a $1000 reward offered to any Chiller manufacture that is colder at 1/4 - 1 mile finish line with any size ice tank up to 8gal and stock HX no ice. No takers so far. 2021 no ice reward!
We are looking for Mustang, Mercedes to prototype Bumper reservoir and Chiller kits 100% bolt-on If you're not happy get a refund and keep the kit
Integrated mounting for chiller with the bumper bar replacement tank?
Looks like otherwise the bumper bar gets cut for chiller install?
TrekGTO
ST PETERSBURG
05 Maggie GTO
V2 test car on the street today 0-80mph. We testing 3 points 2gal reservoir no ice stock pump, HX: Reggie Pull 1_1_ 21.jpg Xtreme Chiller
Prayed.
TrekGTO
ST PETERSBURG
05 Maggie GTO
AI Cryo Tank
2x V2
1x Trackhawk
2x Gen6
2x Hellcat
1x Shelby
1x 2008 Mustang
TrekGTO
ST PETERSBURG
05 Maggie GTO
Group buy $50 discount now till end of the month free Insulation Kit and Shipping!
TrekGTO
ST PETERSBURG
05 Maggie GTO
28 Bumper Reservoirs sold in less than a month!
TrekGTO
ST PETERSBURG
05 Maggie GTO
Hellcat Bumper Reservoir in stock 2+gal
V2 and V3 Bumper Reservoir/Chiller fitted
This is such an efficient system, we have customers taking out expensive trunk tank systems to switch this setup. Better IAT and better AC performance than Chiller with trunk tank.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Bumper Reservoir for Chiller $400 with insulation kit, $50 off when purchased with Xtreme Chiller.
By Pass?? Diaelectric union.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Grape Ape
Braselton
Well now to have a HX, heat exchanger you have to have a 3 way valve by pass with numerous metals. Which takes unions that want deteriate the metals. The black sticky stuff used as insulation,, is a bitch to take off in case of a leak. On the union. Try using 3/4 Armaflex glued in place to be able to remove. Heat exchanger you want to dispurse as much heat as possible. What it is for. Chiller tank itself, don't use the alumium foil taped on insulation. It will get condensated and fall apart. Also use 3/4 inch Armaflex glued in place and it will not peal off. Remember to use Armstrong 520 glue and seal the seams for lack of moisture. To have a better sealent and moisture control. Apply 2 coats of Armaflex white finish works as a vapor barrier and last 3 times as long. The finish is water based,, easy for cleaning.
If you don't like the white, Home Depot will tint it any color for)$$$. Just purchase a cheap 3 inch brush.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thread Starter #20
Hellcat Competition Xtreme Chiller / Bumper Reservoir with HX Bypass upgrade for Installing Dealer SVS Performance, El Paso Texas
